ETR174 Posted October 22, 2014 Report Posted October 22, 2014 I took my flywheel off today to check on my timing plate after modding mine and the flywheel key snapped in half and also my timing was off by a degree (sorry sprinklerman). I found my dremel so I tried to drill it out more and two of the holes accidently went all the way through so I ordered a Matoon adjustable plate. Anyone know the woodruff key size for the flywheel? I may be able to get it from my local hardware store just need to know the size. Quote
Leadmonster Posted October 22, 2014 Report Posted October 22, 2014 Key looks like it broke funny. Like it was pinched. Quote
ETR174 Posted October 22, 2014 Author Report Posted October 22, 2014 Well I didn't really know to put it on so I just made sure it sat fine, out the flywheel on and gave the nut hell with an electric impact lol. That's another question I was going to ask was how do you install it? Quote
Leadmonster Posted October 22, 2014 Report Posted October 22, 2014 Make sure the key is in right and tighten it by hand. Get a good clutch tool that has the pegs on it . Use that to hold the fly wheel. Quote
ETR174 Posted October 22, 2014 Author Report Posted October 22, 2014 Should the flywheel just slide into place or does of take some handling? Quote
Leadmonster Posted October 22, 2014 Report Posted October 22, 2014 It slides on but it's a taper fit. Sure you can see that. You need to hold that fly wheel to torque it down. Don't use the engine to to do it. Quote
Deadbeat Posted October 22, 2014 Report Posted October 22, 2014 you got the key and keyway in front of you and your asking what size it is so you can get one from the hardware store.. http://www.ebay.com/itm/Genuine-Yamaha-banshee-Key-woodruff-crankshaft-key-flywheel-key-/281439054577?pt=Motors_ATV_Parts_Accessories&hash=item4187132af1&vxp=mtr Quote
ETR174 Posted October 22, 2014 Author Report Posted October 22, 2014 I don't know where my digital calipers went and I thought this would be a question straightforward answer. I want an exact measurement not one from OEM. Quote
hoppedupandcutdown Posted October 22, 2014 Report Posted October 22, 2014 They are a touch smaller than anything you will find. Not worth the trouble to buy one and modify it. Get a OEM, and a new nut, just cuz. Make sure the large side will slide easily in the flywheel when it is still off. Set the key in the crank (round side in the crank) The top of the key should be level with the ground NOT follow the taper of the crank. Flywheel should slide on over the key easily. Quote
ETR174 Posted October 22, 2014 Author Report Posted October 22, 2014 Ok yeah I don't know what was up with this key but it stood about a mm over and it wouldn't really guide one. Well fuck looks like I'm going to the stealership tomorrow. Quote
Deadbeat Posted October 22, 2014 Report Posted October 22, 2014 so your keyway is a bit fucked out and your thinking, get something a bit bigger and shave it down so in fits snug? judging by your timing plate mod what fucking chance do you have of making non OEM parts work on your bike? so buying a brand new key and torqing the the flywheel by hand instead of rattlegunning the shit out of it is not an option... you`ve been lucky so far that you havent burnt that motor down....luck runs out 1 Quote
ETR174 Posted October 22, 2014 Author Report Posted October 22, 2014 so your keyway is a bit fucked out and your thinking, get something a bit bigger and shave it down so in fits snug? judging by your timing plate mod what fucking chance do you have of making non OEM parts work on your bike? so buying a brand new key and torqing the the flywheel by hand instead of rattlegunning the shit out of it is not and option... you`ve been lucky so far that you havent burnt that motor down....luck runs out Yeah I'm not sure how its still good. I finally got to compression testing it and got 125 psi on both cyl. My cousin was a dipshit when I asked him what the compression was after he rebuilt it last. Quote
Deadbeat Posted October 22, 2014 Report Posted October 22, 2014 dipshitness runs in the family...Swiss Family Dipshits...stuck on Island Ignorance Quote
ETR174 Posted October 22, 2014 Author Report Posted October 22, 2014 Lmao he's just hard headed about shit that's all. Quote
