One of the domes in my stock head has a small hole about 1.5mm. I have never messed around with domes or know much about them.
Are stock domes replaceable or do i need a new head? I have a option to buy a Athena cool head with 68mm 19cc domes... can i run this with a stock engine on normal pump gas?
Edited by Rapture
Stock domes can not be replaced head is one piece. Why would you run a 68mm dome on a motor that has 64mm pistons in it. To answer your question no that will not work.
Better question. What fuel do you wanna run? 21-22 CC should be ok for the fuel you get out of a pump there. 20 and under will require some octane.
Ok thanks.
