0d6d77bd6635cdd78853a4b93a75f838.jpg2fbf13d3a572af1fe9948aa153864f45.jpgf725a88a8ba57346db19963715e1763e.jpga0b1c5ce602f8c38b4bb0367f9c48d47.jpg
What FMF pipes is this? The o-ring fits on the cylinder, but as you can see not into the pipe. My T5 has a groove inside the pipe for the o-ring.
When I slide the pipe on the cylinder without the o-ring it only has little play, but it blows exhaust out around.
What do I need.to mount the pipes right?
Edited by TJR
Thanks. Don't know if it's good or bad news^^^^^
So how did they seal up at the cylinder or they just didn't.
Clean it all good and some high temp exhaust sealer?
i would measure up the what you need to see what available to fit in the bottom of that flange, i dont think many really early pipes had orings in the flanges
Those are just early pipes. Probably 20-25 years old at least. No o ring to seal. It just slips on the flange. You can try using brake cleaner on the flanges of the cylinder then use red RTV.
  • 1 month later...
