arielblazed94 Posted September 10, 2014 Report Posted September 10, 2014 (edited) I have a banshee and i wanna purchase new jets for it since the ones it has are old and i can't even see what size it has on. The bike seems to really bog at low rpms but then again banshee's are like that, but here are my specs:Full Fmf Powercore 2 Stock Reeds Stock Carbs 32:1 Mix RatioAirbox w. Lid Off Foam Filter w. Filterwear Elevation 600Ft > Temperature 80-90 F High Humidity Edited September 10, 2014 by arielblazed94 Quote
jriffe23 Posted September 10, 2014 Report Posted September 10, 2014 If everything is correct banshees are not like that. Jetting is not my cup of tea. Goodluck. Just my 0.02. Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted September 10, 2014 Report Posted September 10, 2014 Delete the double post with no specs. Quote
Larry's Shee Posted September 11, 2014 Report Posted September 11, 2014 What would help is if you listed what your current jetting is. Might be an underlaying problem. Start with pussy clean carbs and correct float height. Main, pilot, air screw, clip# ????? Quote
arielblazed94 Posted September 12, 2014 Author Report Posted September 12, 2014 how can i delete the post Quote
