fasstbanshee Posted August 16, 2014 Report Posted August 16, 2014 Trying to fit anew set of carb boots to do my v force 3 reeds am I missing something here the boot has rubber sticking out not allowing it to fit flush with the new reads it fits into the rectangular holel of the old reeds but not the vforce 3 Quote
fasstbanshee Posted August 16, 2014 Author Report Posted August 16, 2014 Should I cut the rubber off to fit? Quote
Bennett131 Posted August 16, 2014 Report Posted August 16, 2014 Try a razor blade that rubber is tough. Quote
trickedcarbine Posted August 17, 2014 Report Posted August 17, 2014 After you cut it, make sure to put 400 grit on something flat and figure 8 it on there to make sure it's actually flat. Then move to like 800 Quote
fasstbanshee Posted August 19, 2014 Author Report Posted August 19, 2014 Thanks for the advise guys i did all that and it worked perfectly Quote
camatv Posted August 20, 2014 Report Posted August 20, 2014 if you got the reeds new i believe in the structioonz it sayz to do that. if not welp now ya know. and knowing is half the battle. Quote
