I meant when you install the new parts you will have to adjust the eccentric pin so that shifter Paul or the shifter arm has even throw on each side of the shift drum pins. And the Bikes name is stitch. murenebe.jpg
It shifted fine, and then I changed the case on the one side of the engine. I think something isn't lining up in there. We'll pop the case off tomorrow and check everything
What we've got here is failure to communicate. The cover over the clutch is called a clutch cover. Not a case. The cases are the main engine part that splits top and bottom.
