Piston Travel vs. Crank Rotation
d = ((S/2) + L) - (S/2 cos X) - L sin[cos-1 (S/2L sin X)]
S = Stroke (mm)
L = Connecting Rod Length (mm)
X = Crank Angle Before or After TDC (deg)
I think 30 degrees BTDC is pretty common. If someone wants to  solve that equation for d, then convert from mm to inches that should give the answer. X = 30.
I've honestly forgotten how to use some of those functions on a calcutor.
