10milmike Posted July 19, 2014 Report Posted July 19, 2014 Has anyone run a boss nos kit with smart box? Just looking for a little info on them bought this kit new/ used and no booklet with it. Any help would be cool. Quote
Dixie normus Posted July 19, 2014 Report Posted July 19, 2014 I had one. Worked great. You get different size/hp nozzles for the injectors from bossnoss. Mine worked flawless Quote
n2otoofast4u Posted July 19, 2014 Report Posted July 19, 2014 Fuck those things. You are purely limited on what they give you. It's not like you can fine tune with fuel pressure or anything. What they give you is what you get. Quote
10milmike Posted July 19, 2014 Author Report Posted July 19, 2014 That is what I was thinking green. I am use to wet system's that you can tune. Quote
n2otoofast4u Posted July 19, 2014 Report Posted July 19, 2014 They work decent on the sleds because of the vast swings in temp and altitude. But on anything that is drag only I've only seen them cause havoc and support weisco. IMO if you're used to a traditional system you will hate it. Quote
10milmike Posted July 19, 2014 Author Report Posted July 19, 2014 Yea. Think I am going to get a NX kit. And use a fuel pump. Quote
n2otoofast4u Posted July 19, 2014 Report Posted July 19, 2014 Buying a kit is kinda a waste. You can piece a setup together for less money and get what you want. In the end all that's worth using out of their "kit" is the nozzles, solenoids, relay, and bottle. Their pump is useless, more often than not the lines aren't the right length, mounts are junk, etc. Map out a well designed setup and just order the parts to build what you want. Quote
10milmike Posted July 19, 2014 Author Report Posted July 19, 2014 Well that's what I am going to do green. I have built a few kits when I was younger. Just wanted to see if anyone had any experience with this smart box. It's new to me. Just stay with what I know. Quote
