ryanrogers Posted June 10, 2014 Report Posted June 10, 2014 my bike is pushing coolant into the cases and i'm not sure where from. it is a fresh rebuild with about 2 hours on it. Quote
Surfrjag Posted June 10, 2014 Report Posted June 10, 2014 Into the crank section or the clutchcover part? Quote
ryanrogers Posted June 10, 2014 Author Report Posted June 10, 2014 it seems to be in the clutch but i'm not sure it just starts pushing oil out of the dipstick/ fill plug but i did put a new o-ring on the coolant tube Quote
Surfrjag Posted June 10, 2014 Report Posted June 10, 2014 Sounds like your water pump seal is bad Quote
Starwriter Posted June 10, 2014 Report Posted June 10, 2014 Only 2 ways coolant can get into the clutch cover. Bad waterpump seal or you pushed the water tube O ring out of place when you put the clutch cover on and it's pinched in between the cover and the case where the gasket is. Always put vasoline or something on the O ring so it slips into the clutch cover properly. Quote
03DMshee Posted June 10, 2014 Report Posted June 10, 2014 Only 2 ways coolant can get into the clutch cover. Bad waterpump seal or you pushed the water tube O ring out of place when you put the clutch cover on and it's pinched in between the cover and the case where the gasket is. Always put vasoline or something on the O ring so it slips into the clutch cover properly. And make sure your coolant lines arnt mixed up with your trans vent lines Quote
Starwriter Posted June 10, 2014 Report Posted June 10, 2014 And make sure your coolant lines arnt mixed up with your trans vent lines Has somebody actually done that? LOL Quote
03DMshee Posted June 10, 2014 Report Posted June 10, 2014 Has somebody actually done that? LOL Hahahaha...yup...when we bought my wifes bike they had the lines from the overflow bottle mixed up with vent hoses and coolant was filling the trans...crazy shit Quote
SVO85 Posted June 10, 2014 Report Posted June 10, 2014 Hahahaha...yup...when we bought my wifes bike they had the lines from the overflow bottle mixed up with vent hoses and coolant was filling the trans...crazy shit My bike had the exact same issue when I got it! Quote
