DirectIntelect Posted June 1, 2014 Report Share Posted June 1, 2014 Ok. Wtf is going on.... Two weeks ago had my ported serval running 20/10/9 rears. Spins like crazy in the trails, so switched to 22" ambush. Now can barley ride without using gears 1 and 2.. Now how the hell is my ported 421 serval with 35 pwk, +4 timing, sheerer SB, pods, and lockup not able to launch me in 2nd with 14/41 gearing? Ok, ok, I am 270 LBS but for god sakes can't get out of the hole in second? Smfh........ Btw I have not touched the engine since I got it back from redline. When I got it I was in complete satisfaction...can tire size really make such a difference.... Thanks o banshee gurus..... I'm open to recomendations. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted June 1, 2014 Report Share Posted June 1, 2014 Your tire got 10% taller Gear ratio needs to go up 10% to match. Previous ratio - 14-41 = 2.92 2.92 +10% = 3.22 Drop a front tooth and run 13-41. That will get you 3.15 Or drop one in front and add one in rear for 13-42. That will get you to 3.23 1 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 1, 2014 Report Share Posted June 1, 2014 Yep, it's just too much tire.. I run Ambush and know them very well.. If you want to run 22" Ambush you need to re-gear. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted June 1, 2014 Report Share Posted June 1, 2014 Yep, it's just too much tire.. I run Ambush and know them very well.. If you want to run 22" Ambush you need to re-gear. Or build a 18- 20mill DM 1 Quote Link to comment Share on other sites More sharing options...
Dixie normus Posted June 1, 2014 Report Share Posted June 1, 2014 Nitrous FTW Quote Link to comment Share on other sites More sharing options...
DirectIntelect Posted June 1, 2014 Author Report Share Posted June 1, 2014 Thanks guys. You guys really know your stuff. I can always rely on HQ Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 1, 2014 Report Share Posted June 1, 2014 A 4mm Serval will pull 22" Ambush with 15/41 gearing and a 180 pound rider.. I know that for a fact. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted June 1, 2014 Report Share Posted June 1, 2014 What swing arm length? Sent from a van down by the river Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted June 2, 2014 Report Share Posted June 2, 2014 What are yall suggest for my 521 serval with ambush tires. That's the tires i will run front and back. i had in mind trying 15/41 to start. I need to order new sprockets regardless. I'm not knowledgeable with the off idle power of these big engines. With my old 4mil, i had to slip the clutch a bit more than i liked with 15/41 and pro wedge 2's. I weigh 165 with gear. Quote Link to comment Share on other sites More sharing options...
DirectIntelect Posted June 2, 2014 Author Report Share Posted June 2, 2014 What swing arm length? Sent from a van down by the river Stock Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 2, 2014 Report Share Posted June 2, 2014 What are yall suggest for my 521 serval with ambush tires. That's the tires i will run front and back. i had in mind trying 15/41 to start. I need to order new sprockets regardless. I'm not knowledgeable with the off idle power of these big engines. With my old 4mil, i had to slip the clutch a bit more than i liked with 15/41 and pro wedge 2's. I weigh 165 with gear. You need at least 16/41 with 22" rear tires. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted June 2, 2014 Report Share Posted June 2, 2014 Wow, i did not expect a 16t front sprocket! I guess i under estimated the engine. thanks. Ill have to get the dremel out on my case saver to fit it. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 2, 2014 Report Share Posted June 2, 2014 Wow, i did not expect a 16t front sprocket! I guess i under estimated the engine. thanks. Ill have to get the dremel out on my case saver to fit it. I'm pretty sure rjdgriff is running 16/41 on his 465 Serval. He's probably not quite 165 pounds. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted June 2, 2014 Report Share Posted June 2, 2014 22" tires and a stock swinger with a 270lb rider is a lot of traction. Sent from a van down by the river Quote Link to comment Share on other sites More sharing options...
camatv Posted June 2, 2014 Report Share Posted June 2, 2014 weight of driveline matters too. Quote Link to comment Share on other sites More sharing options...
