Okay here is the story, I got this banshee off a friend and it was a basketcase to say the least. I have a new crank, top end, coil, it had dmc 916 pipes, 28mm mikuni tm flatslide carbs, with 250 main 35 pilot, 5l1 needle on 2nd to top clip, aftermarket cdi and stator.
When I run the thing, it idles okay and has good power down low, but as soon as I hit the throttle it falls flat on its face. I have tried different main jets and it does not seem to make a difference in the symptoms. The only thing i have not replaced was the flywheel, the studs have slight wear marks on them from when the crank bearings were worn. I did put a different pickup coil in it as well, which I am wondering if the connection at my insulated butt connectors may be arching possibly.
Also I the cdi is a monocurve cheapo off of ebay, I tried 2 different stock cdi boxes and they would not even let it start.
I really hate to keep throwing parts at this thing so any advice would be greatly appreciated.
Did you try any mains bigger then 250? Pull the petcock out and make sure screen is clean. Check float level. It kinda sounds like its starving for fuel.
Yea i know 250 is kind of lean but my plugs are black, i had 280s in it before and when i went to the 250s it did not seem to change how it ran. I do have a set of 300 mains i could throw in it. Hopefully i can get some time tomorrow to work on it again.
It is aftermarket, I'm not sure which brand oit is though. I am thinking maybe it needs a flywheel and stator.Maybe the stuffs being slightly worn is making it not spark well at higher rpms.
Carbs are spotless, the thing is very sporadic and it never has run correctly. I replaced everything except for the flywheel. The plugs are br8es. It has no air leaks either.
I faught this on one of my bikes. Swapped every electrical thing on it. Carbs. Reeds ect. Passed leak down too. Finally split it to find a small tear in a crank seal. Now how it didn't leak on leak down idk.
