v2004banshee Posted May 25, 2014 Report Share Posted May 25, 2014 (edited) I just finished building a ported 10 cub. Im running fast fibers and a mattoon lockup. This quad should make about 110 hp 59 torque. What would be a good starting point for springs and weights. I have read the lockup tuning thread and im still not sure where to start. I have to drive about an hour to my riding location and dont want to waste a trip on a slipping clutch. I just want it to not slip but i dont want a crap load of spring and weight if i dont need it. I was planning on running 3 heavy fast springs and 3 tusk springs. Leaving the fingers and weights alone with how they came. I weigh about 220. Thanks i figure this is a common motor on here. Edited May 25, 2014 by v2004banshee Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 26, 2014 Report Share Posted May 26, 2014 Not a bad start. Get a big jug of oil and some stock springs to play with. Stop at a hard ware store or somewhere you can find nuts, bolts, weights, etc. Take some tools. It's kinda fun to dial a bike in first for an hour or so. Then you can enjoy the rest. Don't just gamble and then hope the trip is cool. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 26, 2014 Report Share Posted May 26, 2014 Are u drag racing you would be surprised how little base pressure I run. IMO if you don't have a spring tension gauge your guessing . My advise is set it up heavy in weight till you have time to mess with it ,I have a ton of cut springs that I use to set up people's bikes but I have all the tensions marked on a bag so I know where I'm at . FYI I always keep pressure on the clutch pack consistent equal on all six springs 1 Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted May 26, 2014 Report Share Posted May 26, 2014 Is running 3hd/3regular springs really needed with that kind of power in a lock up? I thought if there's enough weight, then you can run 6 really lite springs. Quote Link to comment Share on other sites More sharing options...
v2004banshee Posted May 26, 2014 Author Report Share Posted May 26, 2014 Quarries and some drags. Quote Link to comment Share on other sites More sharing options...
v2004banshee Posted May 26, 2014 Author Report Share Posted May 26, 2014 Heavy in weight as in two washers each arm? Quote Link to comment Share on other sites More sharing options...
