pp13bnos Posted May 19, 2014 Report Posted May 19, 2014 (edited) So, I bought a bike with the motor in pieces. The motor was a H.R. 4mm stock cyl, spacer plate. It had a piston come apart and ended up trashing the coolhead dome, and the case. Wondering if I have a piece of aluminum for the scrap pile or a epoxied case. If having it welded up would be a better option, I have several well qualified hook ups. Any input would be great. Edited May 19, 2014 by pp13bnos Quote
BANSHEE CHAOS Posted May 19, 2014 Report Posted May 19, 2014 It could be a good way to test just how qualified your hook ups are. :-D Quote
pp13bnos Posted May 19, 2014 Author Report Posted May 19, 2014 (edited) Lol, that doesn't sound good. Here is another angle. There is daylight through the cracks unfortunately. BTW, in the pictures it looks like there is a hole, but its actually not. Just the way the flash was bouncing off the metal. Edited May 19, 2014 by pp13bnos Quote
camatv Posted May 21, 2014 Report Posted May 21, 2014 i was just about to say the same thing. 4 mill's dont require a trench to be done.. if you can get it welded and the rest of the case is in good shape just fix em.. Quote
pp13bnos Posted May 22, 2014 Author Report Posted May 22, 2014 Ended up being a old school 8mm setup. Probably just going to put the cases up on ebay. Not sure if i'm going to build a 8mm or a 4mm setup....decisions, decisions. Quote
