Frankthetank Posted May 2, 2014 Report Posted May 2, 2014 I need to remove the powder coating that is inside by the rear carrier. Whenever I am on the gas the carrier spins and loosens the chain. I the bolts down tight but I think the powder coating is making it to smooth of a surface against the round carrier. Any suggestions? Quote
locogato11283 Posted May 2, 2014 Report Posted May 2, 2014 Post a picture of the rear of the carrier where the pinch bolts are. Quote
Sandking Posted May 2, 2014 Report Posted May 2, 2014 Razor knife or Dremel. This is why I like the 4 bolt carrier housing. Sent from my SCH-I535 using Tapatalk Quote
Coupelx Posted May 2, 2014 Report Posted May 2, 2014 tighten the carrier in the direction of rotation not against. Problem solved. 1 Quote
camatv Posted May 2, 2014 Report Posted May 2, 2014 it happens with some swingarms.. grind it out with a round sanding drum on a die grinder. Quote
Starwriter Posted May 2, 2014 Report Posted May 2, 2014 Look at the tubes where the pinch bolts go through. See if they are touching each other when you tighten the bolts. I have a chrome Lonestar roundhouse swingarm that I had to grind the slots wider. Quote
hoppedupandcutdown Posted May 2, 2014 Report Posted May 2, 2014 tighten the carrier in the direction of rotation not against. Problem solved. Look at the tubes where the pinch bolts go through. See if they are touching each other when you tighten the bolts. I have a chrome Lonestar roundhouse swingarm that I had to grind the slots wider. I've done both these things to fix the same problem. Works great now. Quote
Frankthetank Posted May 2, 2014 Author Report Posted May 2, 2014 Ok thanks guys. Great input! I will try these tips. I just don't want to clean it out. That bites! Quote
Frankthetank Posted May 2, 2014 Author Report Posted May 2, 2014 Ha. I think that's the exact problem! Quote
