Hellbroke Posted April 29, 2014 Report Posted April 29, 2014 Hey all, new to the forums and just had a couple questions about my banshee which I just bought. The quad has an aftermarket airbox and filter on it and the previous owner has 1/4 inch tubing running from the carb and into the air box. I was told this was done so the carb could receive more air flow but after a bit of riding fuel from the carb will slowly fill the lines. I empty them after each ride but am curious as to what that's about. Also on my last ride I brought it back and it sat for about 5 minute when all of a sudden the radiator gushed out a bunch of coolant, at first I thought it was a loose hose but it appears that the liquid came directly out of the bottom of the rad. Any help on these topics would be appreciated as this is my first banshee. Quote
BUILDER Posted April 29, 2014 Report Posted April 29, 2014 I have never heard of some one running the vent lines or the over flow lines off of the carbs into the air box. That is a strange setup if you ask me! I would just run them out the back of the motor like they were. If the radiator is dumping out the bottom then you must have a hole in it dude. Find yourself a pressure tester and test the radiator and see where the water is coming from. Quote
Hellbroke Posted April 30, 2014 Author Report Posted April 30, 2014 The overflow lines do run out the back of the bike but he has 4 separate lines that run from outlets on the side of the carb to the airbox Also I think the o rings on the headers are gone because its really wet where the headers connect, those are just o rings correct, there are no gaskets as well? Quote
Hellbroke Posted April 30, 2014 Author Report Posted April 30, 2014 Trying to Upload pics but everytime I do It says failed to upload file too big. It's just a picture off my phone. Quote
special06shee Posted April 30, 2014 Report Posted April 30, 2014 Down load tapatalk app. Super easy to post pics Quote
Phelps Posted April 30, 2014 Report Posted April 30, 2014 no line on a carb needs to go to the airbox. sounds like pwk style carbs. the 4 tubes are just vents. they dont need vacuum on them. Quote
trickedcarbine Posted April 30, 2014 Report Posted April 30, 2014 Lotta old school fellas used to plumb the vents to the air box. Kinda a waste of time though. Quote
05-SE-SHEE Posted April 30, 2014 Report Posted April 30, 2014 I think the water your seeing at the bottom of your rad could be from the overflow that is tied off towards the bottom of the radiator. When it overflows it shoots coolant out onto the radiator and makes it appear as if it's coming from the radiator. I'm sure it will stop once the radiator goes empty. Quote
paisaroni_mario Posted April 30, 2014 Report Posted April 30, 2014 Instead of clicking attachment click image thats how you upload pics through tapatalk.. I had that problem too Sent from my SM-N900T using Tapatalk Quote
Hellbroke Posted April 30, 2014 Author Report Posted April 30, 2014 Here is a pic of the lines off the carb I was referring to. Notice the fuel in it. Sent from my Nexus 4 using Tapatalk Quote
Hellbroke Posted April 30, 2014 Author Report Posted April 30, 2014 Sent from my Nexus 4 using Tapatalk Quote
Phelps Posted April 30, 2014 Report Posted April 30, 2014 vents and yeah they don't need to be ran to the airbox. Quote
Hellbroke Posted April 30, 2014 Author Report Posted April 30, 2014 Yah I don't know what buddy was going through. Saying it gives the carb more air. Sent from my Nexus 4 using Tapatalk Quote
Hellbroke Posted April 30, 2014 Author Report Posted April 30, 2014 Do these have gaskets and exhaust o rings on the headers because their leaking. Sent from my Nexus 4 using Tapatalk Quote
