2006 stock motor banshee.
Just ordered the following
Cpi inframes
V force4 reeds
Adjustable timing
Stock airbox. Probably going to order a uni filter or something like that. Nothing fancy
Elevation +640
Need somewhere to start on jetting
Thanks
This is just a WAG.
needles middle clip
27.5 pilots
280 mains
1.5 turns out on the airscrews from fully seated.
Do Not Over Tighten the airscrews!
Just seat them, take note of the screw head slot and turn them out 1.5 turns.
They should be the same.
Do you still have TORS?
Make sure your carb slides are sync'd.
The bottom end is going to suck with CPI In Frame Drag Pipes.
You will have to slip the clutch more to keep the stock port motor on the pipe.
I can't imagine you're riding trails with this pipe set-up, but stranger things have happened.
If you are riding dirty/muddy wet areas?
Do you plan on keeping the airbox and lid?
If so, get the Pro-Design billet intake kit that fits in the airbox and allows you to replace that stock POS stock filter set-up with a K&N Filter and an Outer Wear.
http://www.farmandsandtoys.com/partdetail.asp?partid=457
If you do not ride in dirty/muddy areas, then get two K&N Filters and Outer Weasrs for the stock carbs and remove the entire airbox entirely.
http://www.farmandsandtoys.com/partdetail.asp?partid=330
  • 3 weeks later...
well i did the install today
cpi small bores
vforce 4's
uni drop in
290 mains
27.5 pilots
as someone mentioned, the bottom end is sluggish but it pulls like a raped ape in powerband
idle is perfect as well
would changing anything on the mains help me with the low end, i have 310's i could slap in real quick
i understand the pipes are killing me but why not ask
No worries, just trying to learn here
I understand these pipes aren't designed for what I'm doing
I have not moved the needle yet ethier
Would that or is that still necessity?
I'm okay with it as it is really
I also have a +4 timing plate I need to install, maybe that'll do something
The timing will get you some bottom end back. Also, a new head and domes will help liven it up a bit. Maybe have a stock head milled and re chambered by mull. Just order a used one online and drop ship it
I always read different thing regarding timing plate. Some say it will give more top end and others say it will give more bottom.
^ timing gets the bike low end. Excessive timing up top makes the motor fight itself and won't rev out as well. This is why guys with programmable ignitions set up curves with heavy advance early on, and then retard the timing further up in the revs.
So does adding a timing plate sacrifice top end?
