It really depends on your motor , timing , dome , porting etc. Topend pipes stuff the fuel air mixture back into the cylinders more at upper rpms and maybe less so in the midrange. Thats why it is necessary to check plugchops with a pipe swap. Make sure you check half throttle as well as full throttle totally wound out. It could be richer or leaner and definately make sure it isnt lean at part throttle and rpms to be safe.
