Mattchev Posted January 11, 2014 Report Posted January 11, 2014 whats up guys, i picked up a really cheap 89 banshee recently. motor was just rebuilt, starts up in like one kick. has fmf pipes and has the trinity 2 to 1 carb setup. When quad starts up and when in neutral, there seems to be a slight bog when i hit the throttle to rev it, and it also does not idle--i have to keep giving it gas. What can i do to get more response from throttle and how can i get it to idle? Quote
tdod101 Posted January 11, 2014 Report Posted January 11, 2014 Clean carbs, change plugs get a carb rebuild kit fresh gas good to go Quote
Mattchev Posted January 11, 2014 Author Report Posted January 11, 2014 Clean carbs, change plugs get a carb rebuild kit fresh gas good to go will that get bike to idle without havin to give it gas? Quote
uman1030 Posted January 12, 2014 Report Posted January 12, 2014 probably a stupid question here.. have you adjusted the idle? set airscrew properly? looked at pilot jet size? if the airscrew is set properly yet it still has a slight bog off idle try a larger pilot. Quote
tdod101 Posted January 12, 2014 Report Posted January 12, 2014 You have to increase your idle screw, but start with that, half the time it's a dirty carb. Quote
1CrazyBastard Posted January 12, 2014 Report Posted January 12, 2014 Well thats kinda hard to say have you checked the basics spark, compression, ect.... If it has been sitting a lot or for an extended period of time it may very well be the carbs and cleaning them may solve your running problems . Quote
Mattchev Posted January 12, 2014 Author Report Posted January 12, 2014 thanks for the info guys, didnt really touch anything on it yet...just wanted to get some input on where i should start. Quote
Starwriter Posted January 12, 2014 Report Posted January 12, 2014 On any "new to you" bike, you should start with a compression test and a leakdown test. Quote
Mattchev Posted January 13, 2014 Author Report Posted January 13, 2014 had trouble getting it to idle...had screw all the way in on the carb and was still dieing when i let off the throttle. so i took the screw all the way out and cut a little bit off of the spring that was keeping it from screwing in any further and as soon as i did that, it is idling perfect. just needed to get that screw in a little deeper. still a slight bog when hitting the throttle and when i give it a lot of throttle, it doesnt sound like it revs at high as it should. got a 52 pilot and 180 main jet..gonna try going up on the pilot to get this thing sounding right. Quote
Sandking Posted January 13, 2014 Report Posted January 13, 2014 That set up usually likes a smaller jet maybe 42 to 48 Sent from my SCH-I535 using Tapatalk Quote
Mattchev Posted January 13, 2014 Author Report Posted January 13, 2014 That set up usually likes a smaller jet maybe 42 to 48 Sent from my SCH-I535 using Tapatalk you think a smaller jet would get rid of the slight bog when i hit throttle? Quote
Sandking Posted January 13, 2014 Report Posted January 13, 2014 Possibly Sent from my SCH-I535 using Tapatalk Quote
Starwriter Posted January 13, 2014 Report Posted January 13, 2014 Or you've got such a big air leak that even too big of a pilot can't compensate for it. Quote
Zillaguy Posted January 13, 2014 Report Posted January 13, 2014 Ditch the single carb, and put dual carbs on it.... They are lazy on the bottom with a single carb, duals will make it more responsive... Quote
Strm Trpr Posted January 13, 2014 Report Posted January 13, 2014 Ditch the single carb, and put dual carbs on it.... They are lazy on the bottom with a single carb, duals will make it more responsive...best idea I heard yet.I've ridden both carb set-ups and a well tuned twin carb runs way harder. Quote
