sheerider11 Posted December 29, 2013 Report Posted December 29, 2013 Has anyone seen a backing plate warp like this? I went to change the bushings and noticed wen I took it off. Is that a normal Hinson thing? Or is there something wrong? Quote
Finch Posted December 29, 2013 Report Posted December 29, 2013 pretty sweet. it happens get a new one Quote
sheerider11 Posted December 29, 2013 Author Report Posted December 29, 2013 pretty sweet. it happens get a new oneWhere can I get one? I was just on Hinsons website, all I found was plates for 450s. I couldn't get a site for magnum, just there eBay store. I attempted to drill an oem one once. My father took it to his shop and burned up a bit getting it done. I'm gonna call a few sponsors tomorrow and see what I can get Quote
Finch Posted December 29, 2013 Report Posted December 29, 2013 redline or wildcard i know for sure can get ya backing plates can also order ones from mattoon thatll work Quote
Starwriter Posted December 30, 2013 Report Posted December 30, 2013 Definitely Mattoon. Better plate, better cushions, bigger bolts. http://www.ebay.com/itm/BANSHEE-CLUTCH-BASKET-BACKING-PLATE-CUSHION-KIT-DRAG-By-Mattoon-Machine-/321270617309?pt=Motors_ATV_Parts_Accessories&hash=item4acd3894dd&vxp=mtr Quote
locogato11283 Posted December 30, 2013 Report Posted December 30, 2013 JDS, didn't he make one for tyler in the past? Yes. The aluminum ones don't work! That's what blew apart at the BansheeHQ ride this year. I know Redline has the heavy duty backing plates. He also recommends upgrading to bigger screws. They warp from heat and the cushions pushing against them. I'd just call Redline and get the good stuff. Quote
sheerider11 Posted December 30, 2013 Author Report Posted December 30, 2013 Yes. The aluminum ones don't work! That's what blew apart at the BansheeHQ ride this year. I know Redline has the heavy duty backing plates. He also recommends upgrading to bigger screws. They warp from heat and the cushions pushing against them. I'd just call Redline and get the good stuff. Okay good. My girlfriends trans is there so I'll tell him to throw it in when it all comes back Quote
locogato11283 Posted December 30, 2013 Report Posted December 30, 2013 Okay good. My girlfriends trans is there so I'll tell him to throw it in when it all comes back Let him know ASAP. I don't think he keeps a ton of them in stock. Quote
locogato11283 Posted December 30, 2013 Report Posted December 30, 2013 He could always make it out of SS? I have a couple stainless ones from JD. I haven't used them. Quote
sheerider11 Posted December 30, 2013 Author Report Posted December 30, 2013 Let him know ASAP. I don't think he keeps a ton of them in stock.Just got one from him. He pulled it off a floater he had in the shop. He explained why the Hinson backing plates do what they do. So I got a HD one, HD cushions, and bigger bolts. Now I'm worried about the one in my bike. Quote
2004LEBanshee Posted December 31, 2013 Report Posted December 31, 2013 Mattoon. Heavy ass plate. Stiff bushings and big ass screws. G/l. Quote
camatv Posted January 4, 2014 Report Posted January 4, 2014 the mattoon is the only one i have had decent luck with on a 4 bolt basket. the hinson and most other std style baskets are realy only good for about 75hp. anything more or even just a lot of clutch bashing ( drag racing) will cause the warped backing plate. stock oem backing plates are very very hard. i used to drill them out and re grind them then use larger bolts in existing baskets. THEN i got a matton basket and asked if i could get just the bolts cusions and a backing plate theirs is very thick and cromoly. now after my suggestion they offer the backing plate set in a "kit" you can use them on any existing basket, after drilling and taping for the bigger bolts. OR if you need just buy the mattoon anodized basket from the get go. Quote
m671054 Posted January 5, 2014 Report Posted January 5, 2014 So whats the best non std style basket? not looking for a 10plate but it will need to hold way more than 75hp Quote
Boston Posted January 5, 2014 Report Posted January 5, 2014 <p>How would a titanium plate hold up if you wanted to try and loose a few ounces.</p> Quote
