as i understand these come at 68mm from factory. my question is how many bores do u get out of these and/or what mm can u go up to before resleeving is nessacry?
okay can you give me a little more info on these please. so when a piston gets stuck or burns up what do you have to do
<br /><br />Sometimes if a burn down happens the walls don't get hurt, it will just leave aulm in the bore which can be removed a few ways. If it did infact hurt the cyld wall you will need to have them replated.
do most mechaine shops do replating or do you have to send out to specail places. do they hold up better than normal cylinders?
whats ussual cost for replating? so u allways run same size piston in these and either have to clean or replate cyl?
because research is too much work.
athenas are known to have plating issues but i think the cylinder itself has potential with a little porting and domes.
