Hey everyone i have a 4mill on alky thats giving me hell we had ring break couple months ago an it scared left cylinder so i sent cylinder to millinium got it back an now compression is way off from where it was an its also acting like its going lean spits out both pipes ive afde
Added more fuel to it to the point were i know it was way fat an still didnt help u can block off right carb an left side goes to smoking an running like it should an vice versa im needing help any an all will be appreciated thanks
I am not sure of what your prob is but
1. make sure you put pistons in with the windows facing the intake , not the exhaust.
2. Do leakdown test and ck for leaks.
3. Make sure ringgaps were .010-.012 for install
4. Make sure have carbs totally apart and cleaned.
5. Swap sparkplug wires to the other side and see if a problem switches sides.
6. Check pickup gap , flywheel and key placement.
Blocking off one sides carb and seeing a change in the other.
Pistons are in rite ring gap is 19thou compression before ring broke was 210 now left side is 180 an right is 160 new pistons an rings did leak down didnt find anything pickup is set at a business card thickness why am i getting feedback off my other cylinder when i block opposite side off?
.019 for ring gap seems pretty loose to me....could be experiencing "blow by"? When you broke a ring did it chunk the piston? Possibly something blocking up one of your pipes? Maybe a plug issuse - swap them over? Did you swap the plug caps over like previously stated and see if the problem follows or stays the same? Reed valves in good shape? I know its at the point of frustration but slow down a bit, take ur time and REALLY look into everything that could be the cause, persistence will pay off and you will end up fixing it. Good luck
Its spitting out of both Cylinders tried diff plugs wires caps diff fuel put big dumps in the carbs opened power jets all way open its not smoking like it should when you have it running no restrictions in the pipes ones im using are diff from ones i had on it when broke ring motor just went lazy when i lost that one cylinder an piston was all still there when tore it down
The motor is spittibg an popping out exhaust like it's goin lean but i have 118 main an dumps in 38mm mikunis an before this started with these dumps in it it would load up quick but now it's not
I have not seen it but it could be possible with an intake with the crossover to have vacuum etc from one side make a difference and affect the other side.
There has to be something not together right or ignition not grounded or something.
Confirm that you have
good alky
alky will pour out of your pingle
Alky will pour thru your carbs
All jets are clean , drilled , flow fuel.
Have you for sure confirmed that the piston windows arent facing the exhaust? I just keep asking that because that has happened many times and had symptoms such as yours right after a rebuild.
