4 mill jetting
Jaystre
What carbs are we talking about here?
If we are talking about stock carbs, then you need to pull the carb cap off one carb at a time and use a Phillips screwdriver about 1/8" in diameter.
Remove the screws and plate that holds the cable end and slide spring will lift out.
Then the needle should slide out.
C-clip in the top groove, (blunt end of needle) lowers the needle into the needle jet leaning the circuit.
C-clip in the bottom groove raises the needle richening the circuit.
Middle groove is where I run my clip and it flat out boogies.
You might want to do a 50/50 pump/race gas blend.
Do you have an adjustable timing plate?
If so, what is it set at, and maybe set it to 0* and see if it stops backing out plugs.
Advanced timing increases combustion pressure exponentially vs smaller cc domes.
155psi cranking compression is pretty high on 91 craptane...
