sootman73 Posted October 9, 2013 Report Posted October 9, 2013 I searched numerous times for a thread on this but i mostly get coolhead vs stock. (i don't have the money to buy a coolhead) I am having Jeff @ FAST do a Woods port for me soon and i wanted to know if milling the head would be worth the money? I want to run pump gas but would like to bump the compression up a bit. What compression is safe for premium (91-93) gas? What is a safe amount to mill to not hurt squish? Thanks guys Quote
BUILDER Posted October 9, 2013 Report Posted October 9, 2013 Guess the best way to answer that is for you to tell us what they want to mill your stock head? You can buy a used cool head for pretty cheap so my first thought is no it is not worth cutting you stock one. Quote
sootman73 Posted October 9, 2013 Author Report Posted October 9, 2013 They are only charging me $45 to mill my head. It doesn't need to be done as it isn't damaged i just figured i wanted to do something while i have it all apart. Quote
Starwriter Posted October 9, 2013 Report Posted October 9, 2013 $45 + the cost of an OEM headgasket would be better spent towards a used cool head and a set of new O rings. Quote
Coupelx Posted October 9, 2013 Report Posted October 9, 2013 Why dont you ask jeff what he wants on it. Quote
Banshee SE Posted October 9, 2013 Report Posted October 9, 2013 I have one already cut if your are interested. Quote
trickedcarbine Posted October 10, 2013 Report Posted October 10, 2013 If you have him do it, get the domes rechambered as well as the milling. He'll, that might even be what he is doing but I doubt it. But really you would be better off with an aftermarket head, however there's nothing wrong with a properly set up stocker.(I could only keep my big bore sealed up with a modified stock head.) You should find one used and maybe get Jeff to cut you domes for it. Quote
Coupelx Posted October 10, 2013 Report Posted October 10, 2013 My .02 A milled stock head is only worthwhile on an unported cylinder. Remember the dome design is 25+ years old. Max is .025 to .030. A squish test before hand will tell. Now a rechambered head is worthwhile. It is my preference on a stock cylinder. No fuckin orings. Mull engineering did mine for about a 100 bucks. Quote
sleeper06 Posted October 11, 2013 Report Posted October 11, 2013 Mull does all my heads worth the money Quote
BeeCanBanshee Posted October 11, 2013 Report Posted October 11, 2013 Can a stocker be milled to use on stroker motors?alky? and is it worth while in that sence? Would be cool to have a complete sleeper in alky. O-rings are a pain. Quote
Coupelx Posted October 11, 2013 Report Posted October 11, 2013 Sure. Word is they can be cut for a 7 mil crank even. Quote
BeeCanBanshee Posted October 12, 2013 Report Posted October 12, 2013 Sure. Word is they can be cut for a 7 mil crank even. That's what I wanted to hear. Quote
sleeper06 Posted October 12, 2013 Report Posted October 12, 2013 Yes they can I specialize in sleeper Quote
