mailman Posted October 5, 2013 Report Posted October 5, 2013 (edited) I am working on a cub and the cases were ported so much that there is very little material left to properly seal the cylinder to the cases. One area of the base gasket surface is only .045" wide. What is the best way to go to add some more surface area to the top of the case so the base gasket seals? Weld and deck or epoxy? Edited October 5, 2013 by mailman Quote
Finch Posted October 5, 2013 Report Posted October 5, 2013 A lil case sealer spread on gasket and kick who ever made it that small Quote
mailman Posted October 5, 2013 Author Report Posted October 5, 2013 I put it together with sealer and did a leak check and it failed due to a leaky base gasket from the right side of cylinder base. Quote
mailman Posted October 5, 2013 Author Report Posted October 5, 2013 Here is a pic to show how thin the base gasket area is. Quote
lms1977 Posted October 5, 2013 Report Posted October 5, 2013 I had the same issue I used epoxy then block sanded it. It worked for me Quote
mailman Posted October 5, 2013 Author Report Posted October 5, 2013 I had the same issue I used epoxy then block sanded it. It worked for me thx lms. How long has the motor ran this way for? Did it pass the leak down test? Quote
possum Posted October 5, 2013 Report Posted October 5, 2013 mine was the same. I wont say who ported them but i just used permatex on gasket and seems to be holding tight Quote
mailman Posted October 5, 2013 Author Report Posted October 5, 2013 interesting possum. Thank you.I just think it is too thin to trust for long term. I will try epoxy and block sand. Quote
J-Madd Posted October 5, 2013 Report Posted October 5, 2013 Use the metal composite gasket and yamabond. Also, if the cylinders are ported that big and you don't trim the base gasket that small, it's a waste anyway. Quote
trickedcarbine Posted October 5, 2013 Report Posted October 5, 2013 Tig weld and block sand maybe even a piece of 800 grit on glass. Quote
Coupelx Posted October 5, 2013 Report Posted October 5, 2013 What jmadd said. Welding would be a last resort. Quote
sleeper06 Posted October 6, 2013 Report Posted October 6, 2013 You chance distorting that and rolling it over with a tig creating a low spot,marine text is best but metal base and three bond will hold no problem I have put together so many nightmares like that with no call backs,motors running hard for two years or better Quote
mailman Posted October 6, 2013 Author Report Posted October 6, 2013 Awesome advise guys. Thanks. It is nice to hear from different people. Any idea who carries the metal base gaskets. I saw an ebay ad for some but they were too thick. I need a .020" thick metal base gasket. I know Redline only has paper in that size. Quote
SOUTHTHIRTY Posted October 6, 2013 Report Posted October 6, 2013 Call PPS ask for art 6364610880 Quote
