Yesterday I installed v force v4 reeds. I cut the tabs off the intake boots made sure everything was flush bolted it up. Started it idle seemed normal took it for a quick spin came back and it had a high idle. It might be the jetting I have a 27.5 pilots stock needle in third clip and a 300 main. My question is there a way to check and see if the Reed gasket are leaking?
Idle May also be high due to lean pilot. Those reeds like one size up from what would normally be in there. But do the leak down, hell you could even use a propane torch to blow UNLIT propane out the tip around all sealing areas and it will change the idle if it sucks in the added fuel source. Thus a leak.
