onlyonelife79 Posted September 25, 2013 Report Share Posted September 25, 2013 So. What are the main factors in selecting the correct domes. I am currently running 4mill standard bore, 22cc domes, 28mm PWK's. I've yet to rip the carbs open to inspect the jet/needles. Previous owner ran 50/50 blend. Bike runs great and has no issues, one kicker every time, rips great through all gears, but I want to know I'm going through it and making sure its right. <two stroke newbie. Thanks all. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted September 25, 2013 Report Share Posted September 25, 2013 Call a builder. There are several great builders local to you! Quote Link to comment Share on other sites More sharing options...
onlyonelife79 Posted September 25, 2013 Author Report Share Posted September 25, 2013 Builders don't just answer the phone and give you all the answers or theyd be out of a job. That's what forums are for. Quote Link to comment Share on other sites More sharing options...
Brap_Life Posted September 30, 2013 Report Share Posted September 30, 2013 Trial and error lol. Pick up a set smaller, 21's or 20's. install them, run a compression test and a squish band test(some solder or gum placed in between the cylinder head and piston, rolled over TDC, measure it with a micrometer). Go from there. Probably just have to throw timing and more alcohol and bigger jets at it. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 30, 2013 Report Share Posted September 30, 2013 Builders don't just answer the phone and give you all the answers or theyd be out of a job. That's what forums are for. A lot of mis-information ,,,that's what forums can be for too. That's why you call a builder and they set you up with what is good,or they have to make it good. People on forums can just spout off whatever regurgitated info they have ,,good or bad...who's going to be able to hold them responsible? Take your pick. 1 Quote Link to comment Share on other sites More sharing options...
possum Posted September 30, 2013 Report Share Posted September 30, 2013 lol builder builder builder... Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted September 30, 2013 Report Share Posted September 30, 2013 Builders don't just answer the phone and give you all the answers or theyd be out of a job. That's what forums are for. No you call a builder, give them info, then they sell you proper parts! FMFS Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 30, 2013 Report Share Posted September 30, 2013 FMFS ^^ New acronym now? Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted September 30, 2013 Report Share Posted September 30, 2013 ^^ New acronym now? For Mother Fucking Sakes Seems that when I call Wildcard, I talk to Brandon when I call or he calls me back shortly their after. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted October 1, 2013 Report Share Posted October 1, 2013 Trial and error lol. Pick up a set smaller, 21's or 20's. install them, run a compression test and a squish band test(some solder or gum placed in between the cylinder head and piston, rolled over TDC, measure it with a micrometer). Go from there. Probably just have to throw timing and more alcohol and bigger jets at it.So, trial and error? That's not the advise I expected from a pro tech like your self. That sounds more like a "parts changer" to me. And gum? That in the service manual? 1 Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted October 1, 2013 Report Share Posted October 1, 2013 So, trial and error? That's not the advise I expected from a pro tech like your self. That sounds more like a "parts changer" to me. And gum? That in the service manual? ^ beat me to it! Quote Link to comment Share on other sites More sharing options...
camatv Posted October 1, 2013 Report Share Posted October 1, 2013 haha there are "formulas" that work with 2 stroke domes. and the banshee being as well known and trial'd and errore'd its easy to get a proper set up. hint hint PD shelf domes only the 22 and 21cc are really worth a crap. the 17cc has the worst shape and width i have ever seen. even the programs i have seen you can put in a totally wrong shape adn it will say its ok. so even those can be way off. if you think the top builders here DIDNT learn from trial and error your totally wrong. Quote Link to comment Share on other sites More sharing options...
