camatv Posted September 23, 2013 Report Posted September 23, 2013 ?? parts are parts. an ebay serval is the same you would get anywhere else. buy from a sponsor and you will surely get a better overall package and most likely good service also. cheetah was first. it is a much better overall design than the cub. ( better head stud spacing, bigger intake, posibility of using powervalves) the the cheetah cub came out its similar internally as the cheetah for the most part but uses all the OEM style parts so the cost seems less ( since you are just pricing a cylinder and not a complete top end) they use the flawed oem head stud spacing, and the smaller OEM size, higher velocity intakes the cheetah serval is the same as the cub cylinder wise it just has very low port timings letting the end user more pick what they want. properly ported they are a lot of fun ( but so are properly ported stock cylinders) Quote
Phelps Posted September 23, 2013 Report Posted September 23, 2013 so if the cheetah is better than the cub how does a 10 mil cub beat a 14 mil cheatah? Quote
Phelps Posted September 23, 2013 Report Posted September 23, 2013 my bad a 10 cheetah. 68mm cub vs a 72-73mm cheetah Quote
DLStryker Posted September 23, 2013 Author Report Posted September 23, 2013 The ebay add has the option of as cast or ported serval jugs. Be careful who you let port the serval. So far, customers from Redline Racing only proved that redline racing is able to port a serval and not lose low end power. FAST does claim the same but the only chart a customer posted, they gained mostly top end and the power band came on later. http://bansheehq.com/forums/index.php?showtopic=160113 I have a dune bansee. Looking for a trail motor on this one!! Quote
RagunCajun Posted September 23, 2013 Report Posted September 23, 2013 so if the cheetah is better than the cub how does a 10 mil cub beat a 14 mil cheatah? the same way a lot of smaller motors beat bigger motors. Set up. it's not just all about who makes more peak power on the dyno. Quote
n2otoofast4u Posted September 23, 2013 Report Posted September 23, 2013 Bigger is ALWAYS better Quote
Coupelx Posted September 23, 2013 Report Posted September 23, 2013 You mean ive been lied to? Bitch said 3 inches was all i needed. Quote
