DLStryker
Recent Profile Visitors
851 profile views
DLStryker's Achievements
  1. Yeppers. Your jetting is in the ballpark. Sounds like you definitely have an air leak.
  2. Lighter throttle pull for my stepson.
  3. What would be a starting point for needle and main jet for 2 into 1 setup? I have a Keihin 34mm PJ carb, FMF Fattys and everything else stock.
  4. 97screamer, read your DMs. I want the Snipers.
      • 1
      • Like
  5. I'm interested! Contact me please.
  6. Any used Sniper Assassins for sale anywhere?
  7. I have stock cylinders with a dune port. 175 psi compression. V force IV reeds. Toomey T5 pipes. PWK 35mm Air Striker carbs. Carb mount air cleaners. My bike guzzles gas and sounds like it is splattering in the 1/8 to 1/4 throttle range. It's not the ting, ting sound. Just kinda a splattering sound. Thing is, it has no hesitation or performance issues. If I'm idling along and nail the throttle, it is instant response. My jets are 50 pilot, DCE needle, 140 main and 4.5 slide. Does that sound right to you. Doesn't that seem fat on the lower end and lean on the main jet? The motor was ported and built by Kip at Dune Trash Racing. I assume he jetted the carbs as well. Most probably have not heard of Dune Trash Racing. He hasn't been building in 15 or 20 years. This bike was stored for many years.
  8. What year of a Warrior spindles will fit an A arm banshee?
  9. A arm. $30 bucks?
  10. I need left and right front spindles. Spindles only. No brake parts etc..
  11. I have A arms that have a 14mm 1.5 pitch thread end(ball joint). Someone said 72 VW bud would fit that thread size and the Banshee spindle. The VW bug ball joint does have the correct thread to screw into the a arm, but the other end that bolts to the spindle is too large to go into the spindle hole. Does anyone know what ball joint will be 14mm 1.5 pitch thread and the other end fits into a Banshee spindle?
  12. My new to me a arms have a 14 x 1.25 thread that the end does not fit a Banshee spindle. Where can I get the same a arm thread with a Banshee spindle fittment?
  13. OK. Clutch is fried on a "new to me" shee. Mods are ported stock cylinders, aftermarket carbs, T5's and +6 in the rear. I'm in between jobs right now,.. so looking for a affordable fix. What is the Tusk clutch like? 45 bucks compared to the $175 for a Hinson. Will a Tusk hold up for a while with my setup? Or any other suggestions? I am far from broke and can afford any clutch on the market... just being frugile while lookiing. Regards,
