Im beginning my motor build today. Its completely torn apart to the cases. I have some questions:
1. What do yall use as oil on internal parts, Crank seals/bearings, tranny, stuff like that?
2. What do yall use to grease the shifting parts?
3. What do yall grease/oil in general during a build?
4. What do yall use as case sealeant?
5. Any secrets that I should know before I start? This is not my first engine rebuild, but its my first banshee engine rebuild.
Its already torn down. Im putting it back together now. What should I do with the new stainless steel bolts that I now have to put the motor back together with?
Are the torque specs the same? Where  can I find which bolts need anti seize and which need loctite?
I torqued mine down all the same.
you can put the antiseize on the threads
Edited by Hilarious
neither one. use the correct sealer for cases if you don't want leaks.  yamabond, hondabond, Toyota oil pan fipg.
don't use rtv on a banshee.
Booooom
Taking pictures of yamabond while driving. Living on the edge, huh?
I'm in the parking lot of a local Yamaha dealership that stayed open a few minutes late so I could get there.
