notatallhappy Posted August 10, 2013 Report Posted August 10, 2013 I have a set of lectrons that i recently bought upp manifolds for. The carbs fit extremely loose in the manifolds. the manifolds are for 38-39 mm carbs. I was told the lectrons i have are 40 mm. Does anyone have the tech specs on lectrons and manifold fitment? Quote
Finch Posted August 10, 2013 Report Posted August 10, 2013 i have 38 lects and i had to get 35mm intakes tight as shit but better then loose but i believe the 36-40 have the same carb body. Quote
notatallhappy Posted August 10, 2013 Author Report Posted August 10, 2013 Which air filters did you end up using?? Quote
Finch Posted August 10, 2013 Report Posted August 10, 2013 No idea I ordered everything from wildcard. I can check when I get home if ya need Quote
