ABQ Posted July 31, 2013 Report Posted July 31, 2013 I know this is noob question but I searched around a bit and couldn't find a definitive answer. I broke my chain yesterday while riding and am looking to replace it. I'm going to go with a new front and rear sprocket. I want to shift the power band down a little bit so I'm going to keep the 14 tooth front sprocket but was thinking of going down one tooth in the rear to a 40. I'm thinking of going with steel sprockets, is there really a big advantage to aluminum ones? What size chain will I need to make this setup work, 520? I'm planning on going with an x-ring chain. Any thoughts and opinions would be nice. I'm pretty new to quads, this is my first. Its a 2003 Shee as well. Quote
locogato11283 Posted July 31, 2013 Report Posted July 31, 2013 You realize that dropping the rear sprocket will give you more top speed right? It sounds like you want to gear the bike down, in which case you would need a bigger rear sprocket. Primary Drive steel sprockets from RockyMountainATV are worth every penny. D.I.D make some nice o-ring chains. Quote
ABQ Posted July 31, 2013 Author Report Posted July 31, 2013 Yes sorry I meant up one tooth in the back. So I guess 42. Quote
locogato11283 Posted July 31, 2013 Report Posted July 31, 2013 Stock length chain is 104. To be safe I'd get 110 links. You can always cut some off. Quote
possum Posted July 31, 2013 Report Posted July 31, 2013 get a longer chain. So when you wanna run bigger gears you can make 2 link, 4 link pieces to add on with another master. Steel is all most ever use. Quote
ABQ Posted August 2, 2013 Author Report Posted August 2, 2013 Well ordered steel front and rear sprockets 42 in the back with a 520 110 link D.I.D x chain. Bought a chain breaker and rivet tool as well. It was on the cheaper side so I hope it holds up. Can't wait to do the install and get back to riding. Quote
ABQ Posted August 7, 2013 Author Report Posted August 7, 2013 So I accidentally broke the chain in the wrong spot and need to add one of the rolling links back in. Does anybody know where I can buy a single replacement pin to add the link and rivet it? Quote
locogato11283 Posted August 7, 2013 Report Posted August 7, 2013 Why not use a regular clip style master link? Quote
ABQ Posted August 7, 2013 Author Report Posted August 7, 2013 (edited) Why not use a regular clip style master link? A picture would be the best way to explain I guess, but I don't have one right now. I didn't break the chain where I could use a standard master link to reconnect the chain. I have a "fork" on one end and a "roller on the other. It is like this = - instead of - - I thought I would be able to just find a replacement pin and put one of the rolling links back in and use a master link and be done with it. I'm having a hard time finding a replacement pin though. I would rather not reuse one. Edited August 7, 2013 by ABQ Quote
possum Posted August 8, 2013 Report Posted August 8, 2013 Cut off the links in the way and connect a master. 1 link shorter should still fit easily. Quote
ABQ Posted August 9, 2013 Author Report Posted August 9, 2013 Cut off the links in the way and connect a master. 1 link shorter should still fit easily. Yeah I got an extra master so I i'm just going to remove that half link and add a link with two master links. Quote
Tommygunn Posted August 13, 2013 Report Posted August 13, 2013 I was told not to use a master link but to pen it together? Quote
