SFB172 Posted July 22, 2013 Report Posted July 22, 2013 (edited) All prices include shipping, please add paypal fees. Vito's Big Bore Cylinders, makes a 421 with 4mm crank. Fresh Nicasil, low hours. -600 V-force 3 reeds, well used -140 Pro design cool head, 18 and 20cc big bore domes, head has some wear on outside and could use fresh o-rings -130 Good set of engine cases, no chain damage -140 Stock flywheel -Make Offer Ignition Coil, stock winding spliced into ricky-stator pickup and on adjustable RS timing plate, No plugs on the end I was using weather pack plugs with it -60 Used 14 tooth and new 15t sprockets -5 each if thrown in with another purchase. TM Designworks case saver - 30 Brand new in the package pivot works front wheel bearings -20 Stock kick starter -Make offer Stock clutch basket with good clutch pack - Make offer Clutch push-rod pancake bearing- Make offer Two complete stock transmissions, I see from searching they have been a tough sell, if you're interested in one let me know. Probably going to be somewhere in the 100 range on those. Bundling is encouraged especially on some of the smaller stuff. I can be emailed at [email protected], if you have any questions or want other pictures just let me know. E-mail is the fastest way to contact me, I get it right to my phone. Thanks, Ethan Edited July 22, 2013 by SFB172 Quote
Banshee SE Posted July 22, 2013 Report Posted July 22, 2013 I'll take the 15t sprocket. pm me your paypal id Quote
sprinklerman Posted July 22, 2013 Report Posted July 22, 2013 Pm'd and Emailed about transmission 1 Quote
2FastTRX Posted July 24, 2013 Report Posted July 24, 2013 Would like the clutch actuator rod and ball along with pancake bearing, the kickstarter and possibly reeds if by well used you still mean they have life left without buying new pedals? Sending email as suggested in your post for easier response... Thx! Quote
sprinklerman Posted July 24, 2013 Report Posted July 24, 2013 Money sent for Flywheel and trans. Quote
SFB172 Posted July 24, 2013 Author Report Posted July 24, 2013 Bump, One trans, 15 tooth sprocket, kick starter, clutch and flywheel SOLD Quote
2FastTRX Posted August 2, 2013 Report Posted August 2, 2013 Quick shipment and very easy to deal with bump for great seller. Thanks for the clutch parts, they should get me moving finally!!! Quote
