fbt551 Posted July 9, 2013 Report Posted July 9, 2013 What would you guys start with as far as jetting 350 198/130 port Stock carbs(don't want to upgrade) Dual pods 170 comp Vf3 reeds What's a good jetting start for T5: Sheared out frames: Quote
fbt551 Posted July 12, 2013 Author Report Posted July 12, 2013 Nobody? Or reference where I can get the info? Quote
J-Madd Posted July 12, 2013 Report Posted July 12, 2013 Start rich and go down. Maybe 30 pilots and 400 mains would be a place to start. That's an odd setup for stock carbs. Quote
locogato11283 Posted July 12, 2013 Report Posted July 12, 2013 T5: 320 main, 27.5 pilot, needle in the middle, air screw .5-2.5 turns out Shearer: 340 main, 27.5 pilot, needle in the middle, air screw .5-2.5 turns out Obviously this will require fine tuning. I believe this should get you close though. The pilots should be right on with you maybe ending up at 30 for both setups. I'd start with those mains and do a WOT plug check to make sure they're close, then work from there. I agree with J-Madd, this is somewhat of an oddball set up. It seems you're trying to do two different things with one motor. Chances are, it's only going to do one or the other well. Quote
camatv Posted July 12, 2013 Report Posted July 12, 2013 i have ran similar motors style's for dunner? its a cheap combo Quote
fbt551 Posted July 13, 2013 Author Report Posted July 13, 2013 Ya I know it's a bit odd but I don't want my bike to look modded I'm running 380s now stock pilots middle on needles and 1.5 out seems to be working but since I couldn't find any info on a similar setup thought I would ask thanks I will try to step up the pilots as I think mine are 25 Quote
