GEDC0068
GEDC0066
did a chop today. let me know what you think i need to do.
trinity head
30mm carbs
fmf gold series into turbine cores
unis with no box
v force2 reeds
330 mains
45 pilots
air screw 1.5 out
needle on 3rd groove. i dont know if its a stock needle it seems flat on the bottom. doesnt come to much of a point. should have got the number off of them to check or show a pic.
3400 ft elevation like always thanks for any advice
Pretty clean with just a little black. I was wondering if the stock needles have a blunt in or have a point. I was thinking of replacing the needles for stock
That looks good by the pics. If you have crisp throttle response and it sounds good the needles may be fine regardless of what they are. I like to chop em at 1/2 throttle and like to see em richer than WOT. They are annoying to ride if rich at mid throttle but dont go quite as lean as WOT. A good brown ring a little wider is fine at half throttle.
Yuh thenk mebe 45 piluts mite indercate thut sumthins weyrd?
i was looking up the 30mm carbs and one site said stock pilots were 40 and stock mains were 250 i think
looks like im getting it dialed in a lil closer which is what i like to hear
i think i got it jetted really close. ended up a 300 main 45 pilot needle at bottom 1 turn out. ran great through all gears might go to 310 just to safer on main. thanks for all the help. i wonder if the compression gauge is off it ran great started on first kick. if its supposed to have more it would be pretty fast. smokes my lt250 which has some upgrades pretty bad
