jsinar Posted July 7, 2013 Report Posted July 7, 2013 I've been running 14/41 gearing, and my top speed's been about 78-79mph, So today I tried a 15/41, and had NO change in top speed, Then I got to reading around about being under powered, so I put the 14 back on and did what the write up says, got to running wide open in 6th, held the throttle pinned and blipped the clutch, and the rpms shot way up, which shows it's underpowered for that gearing, If I drop to a 13, it SHOULD help with that, right? It's already torquey as hell with the 14, But I'll be using more of the power with the 13 right? Quote
jsinar Posted July 7, 2013 Author Report Posted July 7, 2013 What if I back the timing back to 0? I really couldn't tell a difference when I bumped it up. Quote
locogato11283 Posted July 7, 2013 Report Posted July 7, 2013 What write up are you referring to? Quote
jsinar Posted July 7, 2013 Author Report Posted July 7, 2013 I had googled about it on my phone, and something popped up on yahoo answers, Big LONG explination, it was probably wrong anyways tho. lol. I tried the 13, slowed it down by 10mph, tried the 14 and 0 timing advance, no change, It's like this fucker's got a speed limiter on it. I think it's hit 80 ONE time. I don't think it's the jetting because it never bogs down, builds rpm all the way to the top, I guess it's time for a 4mil. Quote
jsinar Posted July 7, 2013 Author Report Posted July 7, 2013 If I leave the 15 in it, will it hurt anything being overgeared? (like starting in 2nd gear in a car) It still pulls good in 1-5, just tops out the same in 6th. There won't be any catastrophic transmission failure or anything? I noticed the other day in the sand, that 1st was useless with the 14. So my thinking, which is probably wrong, using the 15 will give it a taller ratio in all gears, letting them wind out longer.. right? Quote
joey83 Posted July 7, 2013 Report Posted July 7, 2013 What kind of mods on bike? Its going to take more than a stock quad to hit its top rpm at wot 6th gear. Quote
jsinar Posted July 7, 2013 Author Report Posted July 7, 2013 Mods are in my signature, but as far as internal work, No idea. Never been in the engine. Quote
Buckwheat Posted July 8, 2013 Report Posted July 8, 2013 I have a stock bore / stroke non-ported bike with 21cc domes, VForce 3 reeds, R2 pipes, an aftermarket air filter, 290/27.5 clip middle jetting, running 14/38 gears and I gps'd mine at 83 mph on dirt. It takes it a bit to get on the pipe in 6th, but it will. Quote
BANSHEE CHAOS Posted July 9, 2013 Report Posted July 9, 2013 Wow! Dropping from 14 to 13 is a 10mph loss? Seems a bit drastic... Your clutch is holding tight I'll assume? Quote
jsinar Posted July 9, 2013 Author Report Posted July 9, 2013 IDK, I posted another topic on that, It holds good in low speed, but it acts weird sometimes in high speed. Going by the gps it was 10 less, but it pulled through the gears like a MF Quote
