Bansheedude350 Posted June 24, 2013 Report Posted June 24, 2013 It's not my wiring, it's a brand new. It seems to happen when a half full throttle, i take off my thumb of the throttle but it keep reving at the same rpm. It happened to me 2 times before, i cleaned my carbs both times and i was able to ride for 10h+ before to do it again. I have a TORS eliminator kit and fmf pipes. Quote
vulvafan537240 Posted June 24, 2013 Report Posted June 24, 2013 Sounds like its in the cable or the thumb assembly Quote
jlaits Posted June 24, 2013 Report Posted June 24, 2013 Check the springs also. I had that happen twice at full throttle. The spring on the right carb wouldnt release. Quote
cav4ever Posted June 28, 2013 Report Posted June 28, 2013 Make sure where the throttle cable goes from 1 into the 2 for the carbs is not binding up or pulled apart I had that issue Quote
