jredsbanshee91 Posted June 22, 2013 Report Posted June 22, 2013 i have a 96 banshee that wont spark it has toomey t5s vitos carbon fiber reeds, k&n filter, tors removed, key removed. it has a brand new stator, pickup, coil, end caps, plugs, flywheel, cleaned the grounds and still no spark! it started over the weekend i went riding and it went good for about an hr then it started spittin and sputtering and couldnt get it to come up in the rpms at all, then it died and i couldnt get it to start back up. i pulled cover off and 2 outta 3 timing plate bolts came out and ruined the pick up and dinged the flywheel so i replaced everyhting including the ignition coil. still no spark i tested all the new parts and they r within spec the only things left r the cdi and the voltage regulator but i beleive thats just for the lights right? ne and all help will b highly appreciated!!! i wanted to ride this sunday but thats not gonna happen ;( Quote
ECshee Posted June 22, 2013 Report Posted June 22, 2013 hit it with a hammer. give it a good kick and call it a son of a bitch. Quote
jredsbanshee91 Posted June 22, 2013 Author Report Posted June 22, 2013 ya i wanted to set it on fire aafter it still had no spark its a crappy feeling! Quote
toytech Posted June 22, 2013 Report Posted June 22, 2013 what brand stator? did you set the pickup coil gap? Quote
jredsbanshee91 Posted June 22, 2013 Author Report Posted June 22, 2013 its and rm stator and the gap is set at .015 Quote
toytech Posted June 22, 2013 Report Posted June 22, 2013 (edited) on the rm stator we have we had to put our stock pickup coil on it, they come with a junk pickup coil. Edited June 22, 2013 by toytech Quote
jredsbanshee91 Posted June 22, 2013 Author Report Posted June 22, 2013 the pick up on my factory one got damed from one of the bolts that fell out the ohms check out right idk Quote
jredsbanshee91 Posted June 24, 2013 Author Report Posted June 24, 2013 any other ideas i checked everything again everything ohms out good and checked all my wiring cleaned the grounds to bare metal i have a cdi on the way everything is brand new except for the cdi but i have one on the way ne thoughts? Quote
jlaits Posted June 24, 2013 Report Posted June 24, 2013 I had to cut away some plastic on my rm pickup coil. Try a ground wire from motor to frame. Quote
jredsbanshee91 Posted June 25, 2013 Author Report Posted June 25, 2013 ok weres the best spot to put the ground? under a head nut or someweres else? Quote
toytech Posted June 25, 2013 Report Posted June 25, 2013 I used the bolt that holds the clutch cable holder, and the other end to the coil mount. Quote
jlaits Posted June 25, 2013 Report Posted June 25, 2013 I put mine from the clutch cable holder to the upper rear fender bolt right under the seat. Quote
jredsbanshee91 Posted June 28, 2013 Author Report Posted June 28, 2013 ok i made the ground cable and no difference. i got my cdi box in the mail today and hooked it up....no spark go figure im about ready to bring it to the junkyard.....i checked all my wiring again and the stator is makin power all the way to the cdi (i checked with a test light i wont have my ohmeter/voltmeter till tomoro and yes it was very bright wen it lit up) i tried checking the orange and black coming from the box and got nothing while my brother was kickin it over....so i suspect that theres a signal wire somewere thats f****ed up and not signaling the cdi box to send spark i relooped my key switch, tried looping the kill switch and eliminating it and nothing.....i got soo much money in this thing and i cant ride it i dont have very much money now so i gotta figure this out. is there wires im overlooking? and again all i have is the on/off switch hooked up, im gonna unwrap the harness from the stator connector back and see if maybe theres wires messed up or cobbed from someone b4 me im gonna rip my hair out!!!!! Quote
jredsbanshee91 Posted June 28, 2013 Author Report Posted June 28, 2013 noone has nething? should i try removing some plastics from the pick up or do u think the rm pickup is junk? wut pick up can i buy thats decent? and i had a guy take a look at it he tested every circuit with his snap on tester and everything was fine. is there neway u can test the pickup besides resistance? the coil isnt getting ne signal from wut we could tell so either the pickup isnt reading wen to fire or the cdi is junk right? even tho i tried 3 cdis and they all changed nothing Quote
