jredsbanshee91
Everything posted by jredsbanshee91
  1. ya thats sux neone else? all these members with tons of expeirence dont wanna help a fellow banshee owner out?
  2. neone else have ne ideas? if so plz respond ive bealin with this for 2 weeks now should i try puttin my stock stator back on(it still ohms good and didnt get ne damage) and just put a new pick up coil on it and try that?
  3. ok will do and i checked for continuity thru all the wires everything seems fine ieven checked the voltage from the stator and its fine all the grounds r good as far as i can tell and the coil is good also it was bench tested power is getting to the cdi but something is keeping the cdi from sending to the coil and idk wut it is and idk how to check if the coil is getting any power wen u kick it over.
  4. noone has nething? should i try removing some plastics from the pick up or do u think the rm pickup is junk? wut pick up can i buy thats decent? and i had a guy take a look at it he tested every circuit with his snap on tester and everything was fine. is there neway u can test the pickup besides resistance? the coil isnt getting ne signal from wut we could tell so either the pickup isnt reading wen to fire or the cdi is junk right? even tho i tried 3 cdis and they all changed nothing
  5. ok i made the ground cable and no difference. i got my cdi box in the mail today and hooked it up....no spark go figure im about ready to bring it to the junkyard.....i checked all my wiring again and the stator is makin power all the way to the cdi (i checked with a test light i wont have my ohmeter/voltmeter till tomoro and yes it was very bright wen it lit up) i tried checking the orange and black coming from the box and got nothing while my brother was kickin it over....so i suspect that theres a signal wire somewere thats f****ed up and not signaling the cdi box to send spark i relooped my key switch, tried looping the kill switch and eliminating it and nothing.....i got soo much money in this thing and i cant ride it i dont have very much money now so i gotta figure this out. is there wires im overlooking? and again all i have is the on/off switch hooked up, im gonna unwrap the harness from the stator connector back and see if maybe theres wires messed up or cobbed from someone b4 me im gonna rip my hair out!!!!!
  6. ok weres the best spot to put the ground? under a head nut or someweres else?
  7. any other ideas i checked everything again everything ohms out good and checked all my wiring cleaned the grounds to bare metal i have a cdi on the way everything is brand new except for the cdi but i have one on the way ne thoughts?
  8. ii am lookin intop gettin a replacement for my cdi box. preferably a oem yamaha one but i noticed my box thats on my banshee is from a 97 and they swapped the one plugg to fit the 96 wiring harness becuz the vin says its a 96 "T" wen it was running it ran fine so idk if i should get a 97 box and swap the plug or get a 96 box im confused and need some advice becuz i need the bike goin for next sunday plz help!!
  9. the pick up on my factory one got damed from one of the bolts that fell out the ohms check out right idk
  10. its and rm stator and the gap is set at .015
  11. ya i wanted to set it on fire aafter it still had no spark its a crappy feeling!
  12. and has a fresh top end
  13. i have a 96 banshee that wont spark it has toomey t5s vitos carbon fiber reeds, k&n filter, tors removed, key removed. it has a brand new stator, pickup, coil, end caps, plugs, flywheel, cleaned the grounds and still no spark! it started over the weekend i went riding and it went good for about an hr then it started spittin and sputtering and couldnt get it to come up in the rpms at all, then it died and i couldnt get it to start back up. i pulled cover off and 2 outta 3 timing plate bolts came out and ruined the pick up and dinged the flywheel so i replaced everyhting including the ignition coil. still no spark i tested all the new parts and they r within spec the only things left r the cdi and the voltage regulator but i beleive thats just for the lights right? ne and all help will b highly appreciated!!! i wanted to ride this sunday but thats not gonna happen ;(
