Ok so Im thinking of getting a drag/dune port and fresh topend from hjr but got to thinking and his bolt in 4mil kit is basically the same price. What's the better thing to do? Downside to the 4mil is I probably won't have money for a port for a while. Basically is the stock port 4mil going to be slower than stock stroke ported?
A HJR drag port on a stock crank will prolly be faster than a +4 mil crank on unported cylinders. When you go with a stroker crank, you should have cylinders port timing changed to work with extra stroke
Yea if I could I would wait but my top end is due. My end result if I ever have the funds is a 10mil... I didn't search this much but couldn't I get ported then later on get a crank and blaster pistons to match port timings? Or are those pistons only used for stock heads? So even a unported 4mil wouldn't have much gain over stock unported
If I had to choose now, I would get the HJR port on stock crank with a 45 dollar timing plate set at +4 degree and ask about porting cylinders for a 4mil crank later on. You can run the 4mil without porting, Just ask hjr and see what they say.
You will not be disappointed with the stock crank port and timing considering your budget and urgency
Get the 4 mill bottom end, then put Vito's Super Stock pistons in it. (They simulate porting and will boost you 7 more HP.) We have done this combo a lot!
Then later when your ready for porting, you can get that done and go with standard Wiseco pistons. At least moving forward you will always have a good bottom end.
Sure would hate to see you get porting, then have it all trashed when your old crank bearings grenade from all the added power and RPM......
  • Like 1
