Paul76 Posted June 16, 2013 Report Posted June 16, 2013 Pic won't load but it is all pitted up so is the dome.why would it do this? Quote
#1JUANstunna Posted June 16, 2013 Report Posted June 16, 2013 Detonation or something is coming apart. Load your pics of PB or FB and post the links here. Quote
Paul76 Posted June 16, 2013 Author Report Posted June 16, 2013 Maybe air leak I just rebuiit the top end rode it twice now this I got new pistons already but need to now why its doing this Quote
tdod101 Posted June 16, 2013 Report Posted June 16, 2013 Perhaps you didn't install the rings correctly, could have chipped a piece off and it was bouncing around in there Quote
Paul76 Posted June 16, 2013 Author Report Posted June 16, 2013 The rings are ok it was sparking out of the exhaust that is why I took it apart and the piston looks melted with pits Quote
#1JUANstunna Posted June 16, 2013 Report Posted June 16, 2013 Here are the pics of the OP's motor. Quote
dave5.0 Posted June 16, 2013 Report Posted June 16, 2013 Some of that extra 10 pounds of red silicone found its way to the transfers and clogged them up. Ran lean and started coming apart. Quote
Deadbeat Posted June 16, 2013 Report Posted June 16, 2013 fuck thats savage, looks on the verge of breaking up Quote
Larry's Shee Posted June 16, 2013 Report Posted June 16, 2013 Are you saying the previous piston looked the same? Quote
J-Madd Posted June 16, 2013 Report Posted June 16, 2013 Air leak at the base gasket would be my guess. Quote
sheerider11 Posted June 16, 2013 Report Posted June 16, 2013 Should have done a leakdown. You would have known before it happened. Also, why the fuck is all that silicone in there?? Quote
FullThrottle_06' Posted June 16, 2013 Report Posted June 16, 2013 some one siliconed the ever living shit out of those base gskts!! FFS.. Quote
