I know its narrower, but does anyone know if it will fit a shee? Since I am draggin only- and narrower is better, I am wondering if the new Blaster axles fit. I want to make it more narrow- but dont wanna spend 550+ on a drag axle.
The 03 axle would actually be the better choice. Because, since blasters before the 03 had mechanical brakes they used a floating rotor set up...The 2003's use a fixed rotor set up. Either will work, but the 2003 would probably work a little better. And 2000's didn't have a smaller bearing carrier to the best of my knowledge, little to nothing has changed. Major things include- 02 they added brake lights, 03 they changed the brakes to hydraulic and different plastic styling.
I'm an admin at BlasterHQ.com. ANd I used to have one tricked out blasty. :blink:
