Screamin_Banshee Posted October 31, 2003 Report Share Posted October 31, 2003 I know its narrower, but does anyone know if it will fit a shee? Since I am draggin only- and narrower is better, I am wondering if the new Blaster axles fit. I want to make it more narrow- but dont wanna spend 550+ on a drag axle. Quote Link to comment Share on other sites More sharing options...
WhiteShee Posted October 31, 2003 Report Share Posted October 31, 2003 Yep, the 03's fit. So do rappy and warrior axles. Drag axles are way to expensive! Quote Link to comment Share on other sites More sharing options...
cheezehead Posted November 1, 2003 Report Share Posted November 1, 2003 Rapter axles are wider on one side though found that out last week Quote Link to comment Share on other sites More sharing options...
Yamaha350T Posted November 1, 2003 Report Share Posted November 1, 2003 The blasters have the same setup basically in the back. I don't know about the 03 blasters, but the 2000's had a smaller bearing carrier so i'm not sure. Quote Link to comment Share on other sites More sharing options...
BlueBlaster01. Posted November 1, 2003 Report Share Posted November 1, 2003 The 03 axle would actually be the better choice. Because, since blasters before the 03 had mechanical brakes they used a floating rotor set up...The 2003's use a fixed rotor set up. Either will work, but the 2003 would probably work a little better. And 2000's didn't have a smaller bearing carrier to the best of my knowledge, little to nothing has changed. Major things include- 02 they added brake lights, 03 they changed the brakes to hydraulic and different plastic styling. I'm an admin at BlasterHQ.com. ANd I used to have one tricked out blasty. Quote Link to comment Share on other sites More sharing options...
