Vinny_Vincenzo408 Posted May 21, 2013 Report Posted May 21, 2013 What are the torque specs for the cyclinders Quote
rg97 Posted May 21, 2013 Report Posted May 21, 2013 Manual says 28 nM/ 20 ft. lbs for the head bolts AND the nuts thatgo on the jug itself to connect to the crankcase 1 Quote
SAVAGE420 Posted May 21, 2013 Report Posted May 21, 2013 .....as said above, but go in sequence, hand tight,then 10 then 15 then 22....is what i do. The sequence is on the stock head 1 thru 10 Quote
Pastrykiller Posted May 21, 2013 Report Posted May 21, 2013 Turn it till it cracks then back off 1/2 turn. Should be 20 ftlbs Quote
BigRed350x Posted May 21, 2013 Report Posted May 21, 2013 Just wing it. Tighten them down until they strip out, then go backwards a half turn & your good to go. 1 Quote
