Hey Guys & Gals,
Still relatively new to the banshee world, and want to send shutouts to you guys for making this whole experience a blast. With that said, got a new 421 serval from FAST (assembled correctly i hope) after fighting with the jets i still cant quite get it right. Have a 48p/155m, cel neddle 3rd clip, PC pipes, 35mm PWK, 6" Pods, +4 timing, The main issue is after my break in period , the quad all of a sudden started making a weird noise from the stator side. Not sure what it is, but sounds like a lubrication issue. Look at the video and tell me what you guys think, sometimes i just want to give up trying to get these things running tip top....
<iframe width="1280" height="720" src="http://www.youtube.com/embed/2V7LKW0A_7I" frameborder="0" allowfullscreen></iframe>
Exactly like he said ^ ^ . If you hear something from the left side then some things to check would be
Exhaust spring or exhaust rattling , pipe hanger rattling
Flywheel , pickup hitting
Flywheel rattling
Something like circlip , broken ring loose inside motor.
If you would fill out your profile you might have someone close to you that can help you.
