DirectIntelect Posted May 10, 2013 Report Posted May 10, 2013 Hey Guys & Gals, Still relatively new to the banshee world, and want to send shutouts to you guys for making this whole experience a blast. With that said, got a new 421 serval from FAST (assembled correctly i hope) after fighting with the jets i still cant quite get it right. Have a 48p/155m, cel neddle 3rd clip, PC pipes, 35mm PWK, 6" Pods, +4 timing, The main issue is after my break in period , the quad all of a sudden started making a weird noise from the stator side. Not sure what it is, but sounds like a lubrication issue. Look at the video and tell me what you guys think, sometimes i just want to give up trying to get these things running tip top.... <iframe width="1280" height="720" src="http://www.youtube.com/embed/2V7LKW0A_7I" frameborder="0" allowfullscreen></iframe> Quote
dirtydownunder Posted May 11, 2013 Report Posted May 11, 2013 pull the plugs out, do you feel any resistance anywhere by turning it by hand ? Quote
sheerider11 Posted May 11, 2013 Report Posted May 11, 2013 With that said, got a new 421 serval from FAST Have you called Jeff?? That would be my first option Quote
gomerkfx700 Posted May 11, 2013 Report Posted May 11, 2013 Pick up could be barely graising the flywheel maybe. Quote
RadarRacing Posted May 11, 2013 Report Posted May 11, 2013 Exactly like he said ^ ^ . If you hear something from the left side then some things to check would be Exhaust spring or exhaust rattling , pipe hanger rattling Flywheel , pickup hitting Flywheel rattling Something like circlip , broken ring loose inside motor. If you would fill out your profile you might have someone close to you that can help you. Quote
DirectIntelect Posted May 11, 2013 Author Report Posted May 11, 2013 Thanks guys, I will look into it..... Quote
