gomerkfx700
Everything posted by gomerkfx700
  1. Yea they. Could be a little welding will need to be done but they could be cut and put back together
  2. Well I kinda cheated I just bought one modded from a member lol
  3. Has any one tried them for dirt drags. There kinda like a 4snow or pw2 or zippers in size and shape with a different tread pattern. They look more reinforced then 4 snows or zippers
  4. ok was board and reinstalled the flywheel that was on it set the gap at .19 tried it same thing but i noticed something i had over looked before. hear is some pics. as you can see the piece is loose you can wiggle it. is that something that can be jb welded back or do i need a new stator as well. i have a ricky stator new style flywheel coming it was recommended by f.a.s.t. thats what i went with he said the new riveted and bolted style has had 0 failures. so do i need to get me another oem stator on the way or whats your thoughts
  5. Mine are stamped
  6. Pm sent on r6
  7. I can get them drilled just figures someone made 12mm bushings were its a popular swap on other bikes
  8. Do they make 12mm lower bushings or do you guys just take your time and drill them out
  9. How would the r6-r1 shock do for a 325# rider on a +4 arm would it be to soft
  10. Pm sent on alum. Rods
  11. Lol ahh she like ridding also it don't hurt that the sound of a banshee make her a little damp lol
  12. I'm just going to get me another and save the agrvation I've waited 3 years on this thing another week or so won't hurt me
  13. interested in doing any trading on some marvin shaws and adjustable strut i have listed forsale. http://bansheehq.com/forums/index.php?showtopic=174455
  14. ok well the gap was wide and the flywheel sounds like a box of rocks guess i should have checked that before i installed it. ok back to the drawing board. i didn't even set the gap and try it. threw flywheel in trash time to get another. the other two i have sounds the same way so out they went as well.
  15. i have a set of stud mount marvin shaws with 5/8 spindle. they measure 14" from the stud mount to the center of the spindle. was on a hill shooter chassis. don't know the pressure in them but they are stiff i can barely budge them. i also have a adjustable rear strut that is alum. and also made by marvin shaw all the way in it is 11" eye to eye and all the way out with around 3/8 to 1/2" of threads in the strut it measures 13" hear is a picture of how they mounted on the frame i will not send the section of the frame it is to big to bother with and it basically junk i will however cut the top mounts from the frame if you want them. i am asking for 300+ shipping and paypal fees i am open to reasonable offers and trades + cash on some parts. the parts im looking for are these a like new flywheel with no rattle at all and good keyway. a +4 round house swing arm no feather weight stuff must be a sturdy unit a round house carrier with brake plate. 35mm pwk or lecterns of similar size gas only no alky.
  16. Mine is doing just exactly what yours is it will take off to just about when you think ur should come on the pope and it acts like it hits a rev limiter hope fully the weather is nice today so I can try a few things to it.
  17. Its stock stator I'm going to check the gap this evening if the rain quits
  18. gap between the flywheel and pickup coil? i never really considered that till it was mentioned but i suppose it could be i can't even remember if i set it when i put it together been to long but i would say i just put it on and didn't.
  19. no it never gets past the wall. hits it and just stutters like a 4 stroke on the rev limiter. i haven't checked the pickup either. thats on my list for tomorrow. im going to set the timing on 0 check the pickup and i found my 350-360-370 mains i guess ill start with the 370 and come down from there.
  20. im not sure if its the stock needles or not whats the numbers on them and ill look and see i am considering just buying a set of carbs and a intake probably 33 or 35mm pwk
  21. im going to try more fuel soon as i find my other jets i have up to 370s just have miss placed them.
  22. air screw has no affect with the 340's tried 25 pilots it won't hardly start with them at all at 2.5 turns out 27.5's at 1.75 turns seems a little fat idling but got was getting angry because of the rev issue and thats when i said screw it.
  23. other end of the state from you its were ky, va, and wv all come together.
