OK thanks man. I'll pull my bolt out to check it. Prob won't run it for awhile. Need to get a serval built first this swing arm is +4. I'll just run the stock one till I get a motor built
That is not the classic Ebay Swingarm.
My buddy has that same model your showing in a +8 and it's chromoly and nice.
The Swingarm Shop is the Ebay arm guy. Those are mild steel square tube arms. Most have stock carrier designs, but he also sells some round carrier models as well.
I think that one was made by "Tucker"
So is this "tucker" swinger any good. Like I said I have one as well. Basically can I hit some jumps with out it exploding?
Yes that is a nicer swingarm. It is chromoly and strong.
I will say however, that anyone who is planning on doing any serious jumping should really have a swingarm that has the rear carrier gusseted pretty well. That arm would be what I would call a good dune arm. If your ride style is more MX....I'd want more than pipes butt welded to the carrier.
But I would take that over a mild steel square tube arm any day. At the price your getting it at.....you can't pass it up. (But you could re-sell or trade it with someone for a MX style if you need to.)
