87sheerips Posted April 26, 2013 Report Posted April 26, 2013 This is the best. Made my morning. Quote
Vicstuff Posted April 26, 2013 Report Posted April 26, 2013 CFM airbox with pods and outerwears ftw. Problem for op is he said he doesn't have the original airbox mounting tab Sent from my HTC_Amaze_4G using Tapatalk 2 Quote
Scrubtherubber Posted April 26, 2013 Report Posted April 26, 2013 I run a 2-1 but this this has worked well for me Sent from my HTC_Amaze_4G using Tapatalk 2 im working on making something along the same lines, did you use sheet metal or alluminum? Quote
Vicstuff Posted April 26, 2013 Report Posted April 26, 2013 This one is aluminum, I used 20 ga IIRC sheet metal on my old one and it worked fine I just painted it, but it does not work with my new pipes and battery set up so I made this one in about 30 minutes Sent from my HTC_Amaze_4G using Tapatalk 2 Quote
yoder Posted April 27, 2013 Author Report Posted April 27, 2013 I have been riding as is... I guess a good question is how "water resistant" are outerwears Quote
Vicstuff Posted April 27, 2013 Report Posted April 27, 2013 Not very lol Sent from my HTC_Amaze_4G using Tapatalk 2 Quote
J-Madd Posted April 27, 2013 Report Posted April 27, 2013 CFM airbox with pods and outerwears ftw. Problem for op is he said he doesn't have the original airbox mounting tab Sent from my HTC_Amaze_4G using Tapatalk 2 You can use zip ties. Don't have to have air box tabs. Quote
ATVridinMaNiAc Posted April 28, 2013 Report Posted April 28, 2013 Yea i actually dont use my airbox tabs with the CFM box i run. Quote
trav-99 Posted April 29, 2013 Report Posted April 29, 2013 i also use a CFM alum. air box with twin k&n's. i ran open pods on my old banshee and water/mud was ALWAYS an issue and caused high maintance, sucked in water many times and eventually caused the throttle slides to start wearing and chipping off. never again will i run open filters. it really depends on where, and when you ride. in rainy wet pennsylvania you need extra protection. and outerwears didn't help either. 1 Quote
