airbox or splash guard
yoder
This one is aluminum, I used 20 ga IIRC sheet metal on my old one and it worked fine I just painted it, but it does not work with my new pipes and battery set up so I made this one in about 30 minutes
Sent from my HTC_Amaze_4G using Tapatalk 2
CFM airbox with pods and outerwears ftw.
Problem for op is he said he doesn't have the original airbox mounting tab
You can use zip ties. Don't have to have air box tabs.
i also use a CFM alum. air box with twin k&n's. i ran open pods on my old banshee and water/mud was ALWAYS an issue and caused high maintance, sucked in water many times and eventually caused the throttle slides to start wearing and chipping off. never again will i run open filters. it really depends on where, and when you ride. in rainy wet pennsylvania you need extra protection. and outerwears didn't help either.
  • Like 1
