Good to use one with a 4 stroke piston where there is 91280198731 rings per piston. 2 stroke, squeeze by hand as said.
2 pokes can be done by hand . Dont forget....You usually want to gap the rings first before install. Check and make sure there is about a .012 gap with the rings stuck in the cylinder and not on a piston.
.012 I'll be sure to check that Radar....Im wanting this thing to run as hard as I think it should so I need everything to be perfect, Time and Money this winter my wife was really calm and cool with all my purchases and machine work prices
Take your time, if you suspect anything not going smoothly, take the head off inspect everything and try again, a buddy actually broke a ring putting a head on is yz 250 and ruined his weekend trip because he was in a hurry. Not something to rush.
Tonight I installed my Hotrods crank put cases together and primary gear on tomarrow night the pistons jugs intakes getting it ready to pressure check it probablly sun I want the gasket material on the cases to fully set before pressure. You guys say add 6 psi and how long does it need to hold pressure.
